Rollin
- Oct 1, 2009
- Automatic
ok,
I am swapping over the parts from a 90 to a 95 motor and found the oil pans are a little different. Then sensor in the 95 were it plugs in is more flat with looks like two wire plug and the 90 is a single. I figured I would just switch sensors but one is bigger than the other. Then oil pan gaskets are different too and I like the seal on the 95 pan better--so If I just leave the sensor unplugged will it throw a check engine light or code if its not hooked up. I also thought maybe I could visit the pick n pull and grab that plug and wire it into the 90 plug just need to know what the wires plug into if the 90 only has one wire.
Thanks
Mark
Thanks
Mark
