'90 model F-150 Will Only Idle
You didn't say what year the Lariat is, but you can look here for a ECM. You may find some numbers you can search with if you can't find the correct unit.
www.car-part.com
UPDATE: Truck moved to second indie mechanic who did a complete compression check - one cyl had zero compression, two others very low. Warped valves. Low engine miles (46k) may have actually contributed to the problem due to less wear on components & so was stuck tighter than an engine with more miles.
Ill bet it jumped time.
Thatll bend valves. I had a 351w do it.
If you replace the valves check the chain...otherwise itll do it again
Truck sits with fairly large bucks poured into it. Owner can't decide to pour more or sell at a loss.
