You didn't say what year the Lariat is, but you can look here for a ECM. You may find some numbers you can search with if you can't find the correct unit.
www.car-part.com
www.car-part.com
Ill bet it jumped time.UPDATE: Truck moved to second indie mechanic who did a complete compression check - one cyl had zero compression, two others very low. Warped valves. Low engine miles (46k) may have actually contributed to the problem due to less wear on components & so was stuck tighter than an engine with more miles.
