'90-'94 driveshaft into '85 truck
The flange is centered by the 2" pilot circle, redrilling it shouldn't be a problem (you'll need a M12-1.75 tap to cut new threads in the holes. Be careful of the pinion seal as you do this).
good luck not having a vibration afterwards
I checked this weekend, as 4x4Junkie said it locates off of the pilot circle, the bolts just hold it all together.
