90-94 D35 to 95-97 D35
Funnyman141
Fort Madison, IA
I was wondering if I should swap out my 90-94 D35 for an actual 95 up D35 with the twin piston brakes, since my truck is a 95. :icon_confused:
that ands its not so fun walking to a parts store to return the twin piston brake stuff for the split pin brake stuff.
last night I got back from a 40ish mile trip (got called in, then didn't need me :annoyed: ) Since I changed the bearings on the drivers side and the radius arm bushing on the passengers side, I've noticed a quiet squeaking/screech sound that goes with the speed of the tire. About 12ish miles from home it pulled to the right then I heard a pretty loud pop and it straightened out, I got to work just fine. As I was heading home it gradually pulled to the right again but with no pop noise, and it did it twice within a 4 mile time frame.
Any Idea what it could be?
Also the differential seal on the drivers side is loose from the pumkin if that helps any.
If you want the better brakes, its much easier to swap the knuckles and calipers, than the entire axle.
;brownbag; true, lol I kinda forgot about swapping the knuckles, heck if im going to do that i Might as well swap out to D44 knuckles then right? lol
and any ideas on the binding in the front right side?
Well you could, but thats not a bolt on mod.
I'd suggest checking your wheel bearing for that binding issue.
All right will do, would it be safe to drive to work and back tonight? (40~miles)
don't have time to do it before work. :sad:
disciplerocks, I know that it isn't a bolt on affair and that I need to ream the beams for the balljoints and other things.
