90 2.9 un steady idle rpm and no fuel pump noise
happyfast79
I have a 90 ranger ext cab with a 2.9 and a 5 speed. when i start it cold it idles up and down all the time from 800-1400 rpm . also i dont hear any noise coming from the tank, im guessing thats the only pump it has.
And lastly the fuel gauge always reads empty any easy fixes for that or a way to test if its the gauge or the sender?
The cold idle issue could be a vacuum leak, or Idle Air Control valve, there is also an Intake Air Temperature sensor that can fail.
Fuel gauge I am not sure on, may have to drop the tank to test wires.
There is an anti-slosh and gauge sending unit in the tank, if either fails OR has a bad ground the gauge will always show empty.
So you can check ground wires under/behind dash make sure nothing is just "hanging around", lol.
If you can find the wires going to the tank, like in the frame rail, they do have a color code, and you can test the sending unit from there.
Google: 1990 ford ranger fuel sending unit test
Fuel pump is working if you can start and drive the truck.
I just read the codes on an '87 auto with hunting idle at cold start up and got a "41" Running code for always lean. I don't know the fix yet, but soon might. We already cleaned the IAC valve & replaced a filthy air temp sensor first.
It also had a code 33 for the EGR, but don't think that is part of the problem.
The diaphragm in the EGR can crack and leak, this creates a vacuum leak and improper EGR operation.
With engine off, follow the EGR's vacuum line to where it connects to the intake, unhook it and use either a vacuum pump or your mouth, to see if it holds pressure and/or vacuum.
Also feel the metal EGR tube for rust holes, you can't always see them.
