9.50 to 10.50
disciplerocks
July 2011 OTOTM Winner
OTOTM Winner
Solid Axle Swap
TRS Banner 2012-2015
Evansville, IN
I searched around and didnt find an answer. Can I fit 10.5 tires on my rims that are currently holding 9.50 width tires? I don't know the actual rim size unfortunately.
yes it will be fine. depending on the backspacing but you should be fine even if it is a 7in wide rim. these are aftermarket rims right? If they have 3.75in backspacing it will definatly work and if they are 8in wide it would work that much better
Thank you. I dont know if they are aftermarket or not. They aren't obviously factory.
