89-up A4ld pix
alaskan155
washington
was wondering if any one had a picture off a 4wd a4ld in a 89 up column shift ranger, with the Gas pedal Tv cable setup(alll of them execpt electronic trannies) thanks.
trying to figure out how the set the linkage up on my f150 AOD, but i dont remember how the stock cable linkage on the A4ld went, i know my AOD is like the A4ld, shift on bottom, tv cable on top(reverse of mustang), so wonder if i can get some brackets from an a4ld or make something work, but my a4ld is long gone, so i need a pic of someone elses a4ld
anyone, just need a picture of the linkage
I recently pulled the A4LD out of my 89 4wd Ranger so I can't give you a picture of the setup. However, I have all the brackets and other parts as well as the complete shift cable assembly to the column. I don't know what the "tv" cable is you refer to; don,t think mine had one. Mine just had the shift cable direct to the trans shiftarm--other end bloted to the column shift lever. There is also a kickdown cable which I did not remove. If you need any of the parts let me know.
