89 ranger sas dana 30
ranger89er
10+ Year Member
washington state
whats up i got a 89 ranger stock running gear 4x4 lifted 4inches sitting on 35/12.5/15, i wanna do a sas and need some advice/help, iv heard to go with a dana 30 been told it will bolt right into place of the stock dana28. if thats false let me know what i need to do and what parts i need to make that sucker bolt in!
Its false, a Dana 35 TTB will bolt in the place of your Dana 28. Which the 35 is significantly stronger than your 28 but not a SAS.
There are a lot of good threads on here about the Dana 30 SAS swap, TNT is one of my favorites; go check it out.
The Dana35 TTB from an Explorer has many parts in common with a Dana44 (and places much closer to the D44's strength than a D30's). It does bolt right in place of the D28 since you already have a lift on it (without a lift the driveshaft would need shortened 1 inch).
If you absolutely have to have a solid axle, then a D44 is the way to go on a Ranger IMO. No solid axle is 100% "bolt-in", though there are enough parts out there you can get it to be fairly close to it.
Search will be your friend here... Lots of previous discussion about it.
Welcome to TRS.
