On the harmonic balancer, the big pully on the bottom of the engine, the piece behind it. Be sure to unplug SPOUT connector before checking timing.
If timing checks ok, (10* BTDC), move on to doing a vaccuum test. When i did mine i pulled vaccuum right off the back of the upper intake (the part that says " 2.9L electronic fuel injection) reading should be steady around 17-19HG or whatever the unit is. A burned valve will show up during this test.
I doubt fuel pressure is your issue, but spec is 40psi KOEO.
The only sensor related thing i could possibly think of might be a TPS. RonD should be along to tell you how to test that.
That being said, pulling codes wouldnt hurt. Go to o reiley and get a digtial OBD1/EECIV reader. 30 bucks and well worth it. You can check it with a volt meter, but its hard to tell if your a newbie to EFI (which is why i spent the 30 bucks on the reader
