89 Ranger 4x4 super cab gas tank
Aaron285
Boynton Beach, FL
I have a 89 4x4 super cab. The gas tank has multiple leaks. Tried to fix and I’m over it. I know they do not sell any factory tanks online or anywhere.
Does anyone know what yrs use the same gas tank so I can look for someone parting out or selling used.
thanks.
If its a plastic tank it can be welded, plastic welding, its how they are made
1989 extended cab got the 17gal tank before November and 20gal after that, info here: https://www.therangerstation.com/fo...pacity.105436/#lg=_xfUid-1-1585845871&slide=0
So 1989 was a transition year, you would need to see which one you have to know which one to get :)
But 1989 should have 17gal as Nov of 1989 should be 1990 model year production
Thanks for the info and reply. I bought a tank out of a 96 ranger. It is identical to my 89 tank except for the nipples one the sides that clip on the heat shield. which was my issue, those nipples were leaking fuel. I bought the tank for 60$. Everything fits and works perfect.
Good info
Thanks for the update
