BoostCreep89
- Mar 7, 2012
ive swapped a 85.5 svo motor in my ranger 3 years ago, all stock except 42lbs injectors 3'' leaky homemade downpipe and fmic with 3'' piping, ran perfect for two years... it has sat for about a year until i could trailer it to my new home... in the past month ive put ranger rollar rockers/cam, ebay header(donot recomend), stinger 3'' downpipe 3'' straight exhaust,plugs wire ecu( never put the firewall bung back so rain leaked in) new tfi, new coil, cap n rotor, fuel filter, pcv valve, timing belt and radiator hoses.... truck starts right up, idles smooth then when it warms up if i touch the gas it shuts off... cleaned the iac, have a fuel gauge and pump works but doesnt hold pressure, i do not have a coolant temperature sensor, the tps is from the ranger which ive been meening to change so i can adjust it, and im planning on putting 255lph pump(will a 50galph pump be the same?).... any help on y shes doing me wrong???
