89 Front clip on 88 Ranger?
TonkaSTX
I was curious to know what all was entailed in swapping the front clip from the 89 ranger to the 88. Other than the obvious stuff, I'm curious if its worthwhile. I like the more "full-size" style front end.
Well, I believe you have to swap over the core support, and the rest should bolt right on, some stuff may need minor adjustments. I've never done it before.
A member on here, I believe his name was BogginBSeries, did the same swap in reverse minus the core support. He ended up not being able to mount in headlights.
