You're welcome.
Oil pressure is often misunderstood.
Oil pressure means there is "too much" oil flowing from oil pump..................
The oil pump generates a flow of oil to the oil filter and then to the main oil passage, where the oil pressure sender/switch is located.
If the main passage was open at the end there would be 0 oil pressure, there would be oil flowing but 0 pressure.
The pressure comes from the oil being pushed thru small bearing gaps, crank, connecting rods, and cam.
When there is more oil being pushed than the bearings can pass then you get "back pressure" in the system, so oil pressure in the main passage at the sender/switch.
Too much oil flowing than is needed = oil pressure.
Because of the small passages(friction) and gravity the valve train will have the lowest pressure on most engines, hydraulic lifters help by pumping oil up the push rods, but they rely on being refilled by the systems overall oil pressure.
Generally 6psi of pressure at idle is fine, 30psi at higher RPMs, oil also cools the bearings, higher oil pressure increases the oil flow out of the bearings which helps in cooling at higher RPMs.
But increased oil pressure only increases the flow out of a bearing gap slightly, if flow was increased proportionally to RPM then oil pressure wouldn't go up
, it would stay the same, oil pressure goes up because flow from oil pump is increased with RPM but flow out of the bearing gaps stays almost the same, so back pressure increases.
Too much oil pressure can be bad, it will reduce lubrication, and it can also be a sign of a blocked passage.
