89 Bronco II Fuse Link ?
MLB
I am thinking of buying an 89, The guy replaced the coil and hooked it up backwards, were is the main fuse link to look at because he says it won't start now.
Next to the battery about 4" from the battery. It's under a plastic cover . sorry...edit: 4" behind the starter relay....which is next to the battery)
S-
as for a fuseable link? Not sure. But for that? Trace the wires back from the coil and it should lead you to it.
S-
