- Nov 26, 2009
- Manual
Hi all. I just bought an 89 B2 4wd stick. It has an erratic problem with bogging down. The previous owner said he took it to a mechanic and said the problem was the MAP sensor, but this has been replaced, problem still occurs. Sometimes you can drive a long trip with out it happening at all, other times it will happen multiple times in a couple mile drive. It drives fine then all of a sudden there is no gas pedal response... almost a negative response. If you try to give it gas when this happens, the rpms go DOWN. If you turn the key off and start it right back up, the problem goes away. Please help! Truck has new MAP sensor and new fuel pump, both installed by previous owner. Thanks. Also, the AC compressor has been removed and the hoses cut, don't know if this is important, but it might be...?
