89kcmob2
So I've had good luck with my Bronco II so far. I've had it on long road trips (5 hours each way). It was relatively low miles when I picked it up, under 100k with records. I've swapped out almost all of the easy stuff from sensors to shocks.
On a recent trip, after making it the full 8 hours out –with a few days in between– it suddenly died on the highway in the 5th hour on the return trip.
Here's the weird stuff. When I turn the key to run, everything electronic works just fine. However I don't hear the fuel pump pressurize. Now that would tell me it's the fuel pump IF when I turned it to start the starter actually cranked. It doesn't. However, the starter will run if I bridge the two nodes on the solenoid with a screwdriver.
Something is causing both the starter and the fuel pump not to run.
I've replaced the ignition switch, the ignition relay, and the fuel pump relay. Nada. I've read about the TFI issues but that doesn't seem like it fits the bill. What else could be going on?
