89-92 ranger dash intrament issues
Aaron285
Boynton Beach, FL
Im having issue with every gauge but speedo. the RPM says 5000 RPM when idling and temp gauge is maxed, all other are messed up. Could a bad ground be the problem?
Yes.
Something is grounding out behind the dash more then likely. Or the voltage regulator for the gauges took a shit.
Not sure if the regulator would affect the tach though.
The truck was frame off re built using a 500$ 89 ranger super cab 4x4, all wiring harnesses, modules, dash, etc were from 89- 92 rangers. ECM is brand new. Truck starts and runs great but gauges are all screwy. Haven't driven truck and won't for another few months.
