89 2.9l pass motor mount
forgey4x4
Washington
Anybody figure out a trick to remove the motor mount on the pass side, I am about ready to take the sawzall to it. Thanks 89' 2.9l man 4x4
I got it, but what a pain in the ass. There is just no room.
Sent from my SCH-I545 using Tapatalk
I'm in the same situation. What did you do to get it out?
So I'm not the only one? deep well is too tall, regular socket doesn't reach the nut due to the bolt, and a hand wrench has no clearance to turn. so what is the trick?
What about using a thru hole socket wrench set?
Just a suggestion, or maybe a ratcheting hand wrench...
S-
I have a Craftsman Cross-Force ratcheting wrench I use to break it free and then get my 18 socket on a swivel on it. The socket doesn't bit completely at first, but once the nut is loose it doesn't matter.
borrowed a different length deep well from a buddy, and got pretty easy access through the wheel well. would have been even easier if I had removed the tire but it wasn't so bad.
