89 2.9 uses oil
chilsam
chillicothe il
91 branger
89 2.9 uses oil,comp test 183 hi 178 lo.Vac at 18"+ 1 day 17" the nxt has good power & throttle response I cant c or feel any blow by from valve cover,wen idling fine,blip throttle it smokes valve seals? ,guides? intake leak? brok ring but compression is so good any ideas? THANX!
I had a Honda that smoked like crazy after idle at a stoplight. Great compression. Replaced the burned valve seals and that fixed it. Check (or replace) valve seals.
Yep! Valve stem sealing has went away..
Big JIm
10 40!
That's what i was a hope n! 460's and 300's are my cup o tea 2.9's are a new but welcome frontier.THANX!!
