89 2.3L idle problems
Matthodge1992
Got a 89 2.3 5 speed ranger as a project, had a slight miss and a really high idle. checked tps, iac, plugs, wires, all the normals, ran Koeo codes and they came back auto trans codes, found out it had an automatic computer in it, bought a manual computer put it in cleared it out, started the truck and still doing same thing, ran codes again and its only showing code 34, which ive found to be egr valve or sensor, my question is could either cause my problem and if so can i bypass them or what can i do other than just get new parts?
I'd suggest to start with simply cleaning out the EGR tube since they can become plugged with sludge. The EGR valve can get wonky since it is simply a diaphram and works on vacuum...if the diaphram breaks it simply won't open and your other sensors can detect that it is not doing what it is supposed to do...removing exhaust gases that overwork the cat.
Could also be a carbonized EGR; this would also keep the pintle from moving under vacuum. Use some solvent and some gentle tapping to remove the carbon; If that doesn't work, a small jeweler's flathead screwdriver could be useful as a scraping tool.
First thing I would do is to track down the high idle cause.
Engine cold idle will be 900-1,000 rpm
Warm idle 700-750 rpm
With engine warmed up and idling, unplug the connector for the IAC valve, engine rpm should drop down to 500-600 rpm.
If idle doesn't drop that means computer is not setting the high idle, most likely cause is a vacuum leak.
The IAC valve is a "controlled vacuum leak" that's how the computer raises and lowers the idle for cold and warm engine idle, it opens and close the valve to let more or less air into the intake, if your idle doesn't change from cold to warm engine temp then IAC valve may be stuck, these can be cleaned.
Just as an FYI, on all fuel injected engines IAC valves are used, and when you first start these engines the computer will open the IAC valve all the way then close it to set cold or warm idle speed, so the engine should go to high idle then drop after starting, if that is not happening then cleaning the IAC valve should be the next step.
If IAC valve is working you can start by removing one vacuum line at a time from the intake and plugging that hole with your finger, if idle drops you found a leak, check that hose and the device at the end of that hose.
If all hoses check out as OK, then you will need to spray some carb cleaner or starting fluid around the intake gasket and see if spraying at a certain spot changes rpm, if so then there is a vacuum leak at that spot.
Vacuum leak can also cause a miss as it leans out the idle fuel mix.
If unplugging the IAC valve lowers the idle to 500-600 rpm then computer is setting the idle that high for some reason.
Could be computer is not being told that engine is warmed up, that's done by the ECT sensor, but you would usually get a CEL(check engine light) if that was the case.
Could be a MAF(air flow) or MAP(air pressure) sensor giving the computer the wrong air readings.
The 89 2.3 automatic trucks didn't come with egr. Did someone swap to a 5 speed? If so then when you put a five speed computer in a auto truck it is looking for an egr feedback which it will not get considering they didn't have egr. But if the truck was a factory manual truck then i would start with unplugging egr and plug vacuum line and see what happens.
I'd start looking for vacuum leaks in the egr circuit. Should be an obvious leak if it's causing the engine to idle high.
