Monchi88
- Aug 15, 2015
- Automatic
Hey guys I'm new here and I finally joined to get some extended help after I been reading up on the forums.
So I have a 88 Ford Ranger xlt 2.9 2wd automatic. Picked her up for $400 and she ran great when I brought her home. She sat for a month in my driveway while I was touching her up before I get it registered. One day I went to turn it on and itll only crank but not turn on. I noticed the fuel pumps wouldn't prime so that was my 1st move. Changed both fuel pumps and filters and new gas because the old gas was a dark red color and had something looking like mold in it.. still didn't turn on and pumps wouldn't prime. I went to the junkyard to get 2 ECU's just incase one didn't work. Plugged one up that i git from an 89 ranger 2.9 auto and it took a few tries to turn on but when it did it idled perfectly and it'll stay there idling forever. But once I press the gas just a little bit it dies out and shuts off. If I was to floor it it usually wouldn't pass 2500 rpm but occasionally it will.
I now got a check engine light and I got the code 26 which is the map sensor. I put a new map sensor and didn't make a difference. Today I checked the fuel pressure at the rails and it's spot on, 31 psi at idle and 41 psi at WOT (even though it doesn't pass 2500 rpm at wot).
I'm stumped now and only thing I can think of is the injectors or I got a bad computer. What do yall ranger gurus think?
Thanks in advance
Thanks in advance
