88 ranger no spark or fuel
nrthbnd06
ok guys no spark or fuel in my 88 ranger 2wd 2.9 v6 5spd
so far ive replaced the eec and fuel relays
i have power at all the fuel relay wires except the orange and blue wires which i believe send power to the inertia switch
also have power at the eec relay and coil not very good at this stuff could use a bit of help need the truck in a couple days
Sounds like the pump may be bad. When you turn the key can you hear the fuel pump run building up pressure?
The 1988 2.9l should have a TFI ignition system, inside the distributor is a CMP(cam position) sensor, this tells the ignition module and computer that the engine is turning over so to start sparking and to start the fuel injectors.
I would read here and then print the work sheet:
http://www.therangerstation.com/tech_library/TFI_Diagnostic.html
A step by step to ID the problem
Just because you have power doesn't mean you have a way for that power to return to the negative terminal, I.e. Check all grounds.
You can pull up a schematic at http://search.ebscohost.com/
Username: tech
Password: tech
Once you have logged in click the arrc link near the bottom...
