lumpy
After towing a boat for 90 miles i shut the ranger off it was running good , 6 hrs later i cranked it up and it had a bad miss, after about 10 more miles of driving with the miss even know it ran a little better i ran out of gas and after refilling the miss was still there but now it had gotten much worse, well i did limp home but i needed crocerys so i went to a store and then it died for good , towed it to a car maintenance place and they put a new ignition module in it new cap and rotor . now it ran but the miss was still there and the guys at the shop said the had no idea it was a not so good experience for me $376 dollars for that. I limped home and put in a new fuel filter and new high pressure fuel pump no change the miss still there , i drove it to a store like that 3 days ago all of a sudden it smoothed out and ran perfect for about 10 blocks then it started all of a sudden missing again , now last night it died for good it was running like it has bin with a miss but drivable even know my gas mileage was terrible i drove it anyway the only thing i have and i was under pressure to do certain things , last night it died for good now i have a totally dead truck with new plugs new fuel pump and filter new egn module and cap and rotor it will crank over there is very good spark to all 6 cylinders and i have compression and 35 psi fuel pressure i tested both compression and fuel pressure and spark to all plugs , even after injecting starting fluid into the intake it will not even coff of sputter totally dead. oh and the middle spark plug on the passenger side was fouled this morning and before too. but putting a new plug in its place never did make the miss go away. i never checked the injectors i do not know how and have no manual . My question is do i have a broken timing chain and how do i test for a broken timing chain. 2.9 liter 6 cyl fuel injector injected, There is no water missing out of my radiator no water in the oil .
