'88 Ranger 4/5 drop
jasongind
Parkland, WA
I have an '88 ranger and want to do a 4/5 drop on it but have some questions. Ive never done a drop before so im new to this scene. I have found the DJM 3/4 kits out there. And i understand that i can get 2" drops springs for the fron,t but this will take me to a 5" drop up front with the dream beams. I need to know what combination of products to use to get the 4/5 drop. And are there any special concerns or problems to look out for with a 4/5 drop? Also will the 4/5 keep me level afterwards? thanks for all the help in advanced - Jason
If you are looking for a specific kit for a 4/5 drop, you will not find one. As far as getting that extra inch out of you suspension, you can easily cut an inch out of your stock coils.
But I would still recomend going with a 2in drop coil, you are not going to notice the inch nor will it make a mojor difference, because all trucks are different and it may settle different for you.
As far as problems, you will need the ball joint eccentrics, i believe that is what they are called to adjust for the camber issues you will run into, and for level, you will be purty happy with the stance.
so with the 2" coils it will give me a 5/5 drop and that is a pretty level stance. then all i need is the ball joint eccentrics for the camber issue? sweet sounds like a plan, im going to do air on it also. but i got a buddy thats gonna help with that. thanks for the info
