88 bronco II oil pan gasket estimate???!!!
Status
Not open for further replies.
8879ford
Dropped my 88 bronco II 4x4, 5-speed, 2.9 V-6 off at the shop due to an oil leak. I purchased a new oil pan gasket, and a timing gasket set including the front crankshaft seal, timing cover seal and water pump seal. With that being said, the garage charges $75 an hour for labor. They said I am looking at about $525 just for labor, for them to do the front main seal and oil pan gasket. Does that sound right? I thought it sounds a little high. Any advise or opinions would be greatly appritiated because I'm picking up the truck from the shop at noon on tuesday. Thanks.
Please don't cross post the same post in multiple sections of the forums!
Thanks!
Status
