rpstevens
- Aug 15, 2009
- Automatic
I have a 1988 Bronco II with 2.9L engine and A4LD transmission. Brief history: Engine was running fine and one day while driving the flywheel shattered. I replaced the flywheel, spacer and torque convertor. The catalytic convertor went out, blew the passenger side exhaust manifold doughnut and melted the wires for the O2 sensor. Replaced the parts. Engine would run in neutral, but when placed into gear the engine died. Verified the computer codes and determined the fuel pressure was not correct. Replaced both fuel filters, and rebuilt both fuel pumps.
Current problem - engine still runs but rpms will not go higher than 1500 unless we play with air intake. Playing with the air intake the engine will rev up to 3500 rpms, then the engine gets extremely warm and the radiator boils over. Water pump is OK as is the thermostat. Engine still dies when in gear and the computer does not display any error codes.
Does anyone have any suggestions on how to diagnose or fix this? None of the mechanics I have talked to know what the issue is. I have been told it may be cracked heads, but it does not show the usual signs of cracked heads.
