- Aug 11, 2007
- Age
- 69
- Ontario, Canada
- Automatic
- My credo
- Love Thy Neighbor
I can appreciate your having reached a level of frustration that quite a few would have taken more drastic actions by this time...as in parked it and bought something else to drive...so I admire your perseverance.
Were you able to test the fuel pressure while driving? I posted a video a few months back showing another Ranger owner connecting a fuel pressure tester to the FPR and running it up over the hood so he could see what was happening under load.
In his case the pressure did not drop so he was able to move onto something else (if I recall correctly)...but it might show you if and when the pressure is dropping so you can focus on that.
My 89 Tempo was doing something very similar but more often than not it would just die and I'd have coast off the road. That turned out to be a wonky fuel pump that I replaced no less than 5 times in 14 years...frustrating but fortunately it was covered by an extended warranty that I just happened to have bought when I purchased it new from the dealership.
If you have already done that and found no drop in fuel pressure then I apologize...it's easy to forget...
So maybe at this point a good exercise would be for you to go over all your posts and write down in the order what was done (replaced part or cleaned etcetera) and maybe post that if you have time and want to resolve this logically.
I think from recent attempts your greatest improvement that seemed miraculous, was from moving the wire harness around...that seemed to result in instant improvement without anything else being done...which is why I keep going back to a wiring issue at this point.
The idea that the TFI was heating up and causing the failure seemed like the most likely idea before as did the wire harness to the TFI...
