have a 88 4x4 ext cab fm146 that gave problems lately, found that the head on the pass side was cracked. have a 94 4x4 stand cab m50d (runs and shifts good body , interior is totally trashed - 88 is perfect body and interior) was wondering if i could pull the engine and trans and drop into my 88. will the motor mounts, tranny mounts be the same? will use the rear ds from the 88 as length is different. and will i need to change the wiring harness?
Can these be swapped out with the engine and trans togethor or will i need to seperate them? any help would be appreciated, need to get it on the road asap.
