englewoodcowboy
- Mar 18, 2013
- Automatic
My kids truck has stranded him yet again and I believe it to be fuel related. What I am finding is air in the fuel rail. Its building pressure but when you open the shrader valve it is blowing air then fuel. If you bleed it long enough to get solid fuel it will run for a few seconds then die.
Here is what has been done recently in the past:
New in tank fuel pump
New fuel filter
New pressure regulator
Here is what we know:
It builds fuel pressure but it is not stable, the motor will not stay running and the fuel rail has air.
Full tank of fuel.
Both pumps are running when the key is cycled.
No visible leaks from the tank to the fuel rail.
My thoughts;
The only place I can guess it would be ingesting air would be the second in-line fuel pump. If it had an opening between the two pumps we should see a leak as well as between the second pump and the fuel rail. Any ideas? The in-line fuel pump is origional and I have never had it out to inspect it, could it be cracked and ingesting air and pumping that into the system?
New fuel filter
Full tank of fuel.
My thoughts;
