88 2.9 L b2
whcherman
i have searched, posts, resources, and tech library. this is my questions.
i have no spark when cranking except when i turn off the key see one spark directly from the coil connected to a spark plug and grounded.
1. testing hall sensor is done through the spout connector located any where? but i found it. by connecting volt meter to one of the pins and then another to ground?
2. i have replaced a tfi, distributor cap and rotor
3. performed a white wire trigger and got spark
where lies the problem here?
Welcome to TRS~!
Sorry, but I don't have an answer...just suggest posting this in the 2.9 Engine forum you will find in the forums section...most people don't actually look here so it is likely that you will not get an answer quickly...you can also post in the Urgent Help section or both sections since they are both available to you...
