87 STX Highrider fuel/electrical issue
memorex402
North Carolina
So I sold my ranger to my neighbor. When he got it he decided to fix the nasty solenoid wiring it had before me. He got it cleaned up and looking better but now the fuel pump will not cut on. He called me over to help him figure it out but honestly I am at a loss. I think a few of my questions here will be kind of duh. During troubleshooting we have found some odd things.
The oxygen sensor is a 3 wire. One of the pins from the harness side is showing almost 12 volts. Should this be the case?
Which relay is the fuel pump relay? We are having a tough time identifying the relays at the wire colors are either impossible to tell due to the age or the wire colors are wrong in comparison to the schematics.
One of our relays was warm with the key off. We also noticed that the alternator got warm as well with this relay plugged in. We think this is the EEC relay.
I honestly am thinking he has something hooked up wrong as we have a back feed somewhere. When I owned the truck it did not have this issue. I hope the PCM is not toast.
Does anyone have the diagram of the fuseable links and where they terminate.
Any ideas would be great. Thanks. :icon_confused:
EEC relay has a Brown Base, Fuel pump relay a Green Base, WOT relay Black Base(if it has one)
Fusible links will be hooked to Starter Relay on the fender, same post as the Battery "+" cable.
Google: autozone 1987 ranger 2.9l wiring diagram
Autozone has quite a good repair library
You can try this direct link but not sure it will work:
http://www.autozone.com/repairguide...DIAGRAMS/WIRING-DIAGRAMS/_/P-0900c152800781b2
EEC relay powers the EEC(computer) of course, but also powers fuel injectors, TFI(spark) and the Fuel pump Relay, not the fuel pump itself, just gives that relay's coil 12v, EEC then grounds this relay to close it and send fuel pump 12volts from it's own 30amp fuse.
The three wire O2 sensor should have 5V on one pin, one pin read 12V, and one pin read ground.
The 12V and the ground are for the heater circuit. O2 sensor don't read well below 400*F, so the engineers put a heater in them to get them to operating temp quickly.
The 5V line is the signal reference from the computer, and the ground side of that comes from the computer to the back of the passenger side head.
