for some reason it only wants to top out a 3g in gear put out of gear it will blow past three???? and did all 4x4s in 87 come factory with a tank skid plate??
well now im TRYIN to drive it but i cant seem to get this thing fig out it runs fine then will like stumble and run fine then die completely then come back to life and if you just hammer the gas it will try to go then die then try again an repete im goin nutz new O2 new fuel press reg new filter did fuel press test only had 30 at idle book tells me it should have 40 i can get 40 if i un hook the vac line from the fuel press reg
