87 ranger 5.0 swap
Not sure they were on the motor when i pulled it, it was just them two
Its no fun when you are putting some juice to it and those things blow out--been there.
Ill get some press in ones , hopefully setting the motor in sunday night, working 6 days a week split shifts eats up the day, and somehow i still dont have enough money lol
So i decided i wanted a five speed so i picked up a zf5, drove 2 hours and spent $140 is that a bad price? I havent seen many sbf for sale
You stole it at that price, they go usually around 3-500...
SVT
It took forever to find but after buying 4 different trannies i finally made up my mind lol
So it's been a while but with school and work I've been making slow progress ,
87 ranger 5.0 swap
Body lift on
87 ranger 5.0 swap
Coil spring towers
87 ranger 5.0 swap
Tranny
87 ranger 5.0 swap
Most all my parts I need
87 ranger 5.0 swap
One header sanded and painted, also made my own fuel pump block off plate
87 ranger 5.0 swap
Made some progress, now just to put the trans on and do it 20 more times
Does any body know what size the pressure plate bolts would be for a 79 f150 flywheel, off hand?
87 ranger 5.0 swap
Got my flywheel and pilot bearing on
87 ranger 5.0 swap
I broke off a bolt for the thermostat housing and then broke of a cobalt drill bit in the broken off bolt, so now I have a carbide drill bit on the way but in the mean time I started scrubbing and painting parts
I have a pair of full width axles out of a 79 f150 is it worth the swap or would a Dana 35 and a 8.8 do the job? I like straight axle but for affordability and time wise the 35 would be simple also were can I get a cheap set of 4 inch lift springs
Well its getting cold but I finally got the motor and trans in for good I have all the wiring accept the alternator wired fired her up for the first time yesterday, now I just need exhaust, antifreeze, put the interior back in it, axle swap sooner or later, and a throttle cable, my stock one was junk so I got a spectra from autozone and that was a waist I need one long enough I can loop it so I bought a factory one and it should be here Thursday
87 ranger 5.0 swap
Got my gauges in and my trans in finally
87 ranger 5.0 swap
Got the tcase shifter welded up to work and added a grease zerk to it
87 ranger 5.0 swap
Got the 205 up there looks like it belongs
87 ranger 5.0 swap
I picked up a '92 explorer donor for my '86 ext cab 4x4 ranger. dana 35's with the 8.8 rear. I have not started the project just yet, (replacing/rebuilding my '76 302, C4 combo in the '87 2wd after 148k miles at the moment) but you have a nice build and info happening.
