83_rangerdave
- Oct 2, 2009
- Automatic
My friend has a 87 ford ranger that has had almost everything replaced for sensors and even the engine has been too, the problem is the truck wont rev up with the coolant temp sensor hooked up but when its pulled out it revs up fine and then a minute or two with it unplugged it wont run it floods it out and u have too work with the throttle because its flooding out, he saids that the volatage is lower then it suppose too be when checking the sensor allso and the computer has been replaced too what could be the problem here? any ideas or things too check for
