ddman
- Mar 30, 2009
- Automatic
we have had this truck for years and years, been a great little truck. now we are having issues with fuel we think. ran fine one day next day cranks but wont start, pulled a plug and its getting fire, pushed the stratter valve and fuel shot out of it. now, before we had to run a wire to the pump on the rail to a toggle switch then to the battery. and when you turned on the pump you could hear it run real easily, no it like makes a gurggleing sound. thought maybe it was out of gas, so we put a gallon in it and made no differencein the sound. checked all the fuses, and bought a new relay and tried it, no difference. found the inertia switch and reset it, nothing worked. im wondering if the pump in the tank could have went bad and isn't pumping any fuel to the second pump?
