kgates
- Jun 11, 2009
Need some advice on a 2.9 litre fuel system.
Have spark, but won't fire. fuel pump will not come on. I can hot wire the pump and pressurize the fuel rail but still no ignition. I have traced all wires from pump thru the inertia switch and thru the relay on the firewall. Is there a sensor that won't allow the ECM to fire the injectors some place between the relays? any help would be appreciate
