dfinn
- Aug 28, 2010
Hey folks - new guy here.
I've got a 1987 Ranger - 2.9L, 5spd, Electronic 4WD, Ext. Cab, shortbed. The track has an aftermarket second fuel tank. Bought it a few months back, because the body (even though a little dinged up) was nearly rust free, and the frame was excellent for a New England truck of it's vintage.
Here's my issue:
I have replaced the brake-booster three times in the past two months, and the booster failed on me again tonight. Some specifics:
The booster that was in the truck when I bought it (May) seemed older -- like it was either the original, or an OEM from some time back.
When it failed, there was a great deal of fluid in the booster, but not brake fluid (the brake reservoir was fine). Actually, it smelled like gas.
i replaced it with a reman booster from the local NAPA auto parts.
That booster failed in about three weeks.
I then took the truck to a friend's service shop, and he replaced the replacement (lifetime warranty is a good thing).
THAT booster failed in about two weeks.
My friend replaced the booster again, making sure to adjust the booster rod, and check things out all over.
That was two weeks ago, and the booster has failed again, tonight.
(...and the folks who heard me at the time, well, they knew I wasn't happy...)
So, I'm wondering a few things:
- How could gasoline get into the booster in the first place?
- Could it be causing the booster to continuously fail?
- Could it be a bad install of the second fuel tank?
i don't use the original tank - the second one seems to be the one that's connected to the fuel system, and the gas gauge.
Your thoughts, comments, would be appreciated.
Thanks!
- Finn, Massachusetts
Here's my issue:
Thanks!
