howlinghuskie
So im getting tired of my cruise control not cutting out with the clutch so i was wondering how the two switches are supposed to be wired. I found the green wire for cruise control with the jumper however it doesnt seem long enough. Is it wrapped around somewhere or is there an extension wire thats supposed to be connected. also does the cruise control get hooked to the switch with two connectors or to the one on top with the single connector. currently we have the red with blue hooked to the double connector switch and the black ones to the single switch is this correct or do we have it wrong? The truck was originally an automatic and we swapped in the 5 speed out of a different 87 so everything is out of an 87. my truck came factory with cruise and the donor truck had an aftermarket cruise
