Clay46
- Sep 16, 2016
- Birdsboro,PA
- 2.9 V6
- Automatic
I have a 1987 ranger with a 2.9l and the a4ld transmission. Im having a lot of transmission issues and want to swap a manual into it. i have trying to research this but everything i find is for a 4wd and not a 2wd and wanted to know if aside from the transfer case and driveshafts is everything the same to do the swap. From what i could find i could only use a M5OD-r1 or the FM132 correct? I found an M5OD-r1 in a junk yard from a 89-92 model year ranger, would that work. it is a 2wd transmission. and what else could i get from that ranger if that transmission is usable?
