My plan is to attach the dana44 to the original locations and cut the inner passenger axle 1.5-2 inches, based off of the write up on here that looks the easiest. And probably the 4in rough country with new front and rear springs. Hopefully very minimal customization will be neededRear should be fine. Front depends on exactly how you installed the D44. But I would expect any custom fab needed to be minimal. Also might depend on which lift kit you're talking about.
Be aware that there is an issue with the Rough Country lift, if I recall correctly. I believe it presents an opportunity for one of the axle beam brackets to hit the differential. Check the tech library here.My plan is to attach the dana44 to the original locations and cut the inner passenger axle 1.5-2 inches, based off of the write up on here that looks the easiest. And probably the 4in rough country with new front and rear springs. Hopefully very minimal customization will be needed
I think I remember seeing something about that from using drop brackets. I'll look more into itBe aware that there is an issue with the Rough Country lift, if I recall correctly. I believe it presents an opportunity for one of the axle beam brackets to hit the differential. Check the tech library here.
I have the dana28 currently. Definitely swapping that out before I drop the V8 inYeah, that, but a TTB Dana 35 has the same outer U joints as a Dana 44 TTB, the only real gain is wheel bearings which if you keep the tires in tight like they should be isn't a huge problem up to about 35" tires... Some people can't keep shafts in them but I've yet to break one, but I don't have torque, just horsepower...
