bozo4ford
Hi fellow Rangers,
[ 1986 Ford Ranger/2.3L gas/5 speed OD/128,745 Miles/ California Emissions]
Ok, This is my "unlucky every other year California " SMOG TEST ONLY, where I diligently replace my air filter, spark plugs, cap and rotor, (fuel cap, if needed).
The night before doing these changes, I drove to the auto wash stall where I waited for my engine to cool down before spraying Gunk Engine Brite, to clean, to make my work a little more enjoyable, and yes, I did cover the distributor coil, distributor cap, and any other components I did not want to get wet. I was very careful not to use extreme pressure around the aluminum, bendable manifold tubing, which could easily break and water would get down into the engine. I've done the same thing every other year since this SMOG TEST ONLY came into effect without any problems before. (California)
The day after, I took a drive to the store about a mile away and noticed an extreme stalling where I had to keep gas revved up so it wouldn't stall. I could come to a light signal, and without the gas to the pedal, it would just die. I was really afraid I’d get stuck there.
I don't remember doing anything out of the ordinary this time, except TWO THINGS, (1) the plugs I bought were Autolite Platinum (AP5145) and were supposed to be pre-gapped to .44, and I checked only one, which was fine. and (2) A few days earlier I bought a 12oz. can of OCTANE BOOST gas additive I added to half a gas tank. I know it's bad to use these additives ,but on occasion, I usually go with a fuel injector additive. I am the original owner of this truck, and have been told it's only worth $500.00, so what can I lose, but thinking about it now, these 4-banger trucks don't do good with the higher octane, that's why the REGULAR gas is better than the PREMIUM, Ummmmm....could this be one of the problems? Maybe I should filler up right away to "water down" that octane booster...don't know what the heck I was thinking?????
A few years ago, I did replace my TFI Ignition Module, the fuel relay switch, and maybe a fuel sensor, but believe me, this truck was recently running much better before I did all this replacement of the Cap, Rotor, and plugs this time. The (expensive) 8.5mm Hi-performance Mag Silicone Cable spark plug wires I bought two years ago and they looked fine inside each plug wire, EXCEPT for the distributor coil wire on the COIL side, which was pretty dirty.
So for the life of me, I don't know where to look, because this could turn out to be a costly and timely process of elimination. Any ideas?
Has anyone ever experienced the metal contact on top of the rotor inside the cap in the bent-down position? That was weird. So I re-bent it back up, then just threw on my two year old rotor, but it's still missing. I went to buy only a new Distributor plug wire because the old one had a lot of brown residue inside the plug, I haven't put that back in yet.
I always took a permanent marker pen and mark each plug wire from the corresponding cylinder, so I (hopefully) never put them in the wrong order.
This is what I've found on the firing order >
2.0L and 1983 - 1988 2.3L Engines
Firing Order: 1-3-4-2
Distributor Rotation: Clockwise
Silly question...according to this order, looking at the top left of my Dist. Cap, the top left prong #1Cyl, then to the right #3 Cyl. then bottom left is # 4,then spark wire #2 to the bottom right?
Any would be much appreciated. Thank you! Have a great day!
