Codyh00
- Mar 15, 2017
Hey everyone new to the site!
I have a 86 ford ranger 2wd manual 2.0 carb
Onto my problem..
First off I'm not sure that my turn signals worked properly to begin with but I have installed all LED lights in the last few weeks and have since noticed my turn signals aren't working! All my lights work (I've checked all using hazard button) and they blink like they should. When I use my left turn signal all my lights flash like I have the hazards on and the lights on the dash blink as well, when I use my right turn signal nothing at all happens. When I use my hazards they work correctly and everything blinks. Now to complicate things, when I turn my lights on and try to use my signals or hazards they don't work at all, not even the messed up way that they would do. To make things even more complex when I press the brake with the lights off all my lights will light up like I have the flashers on as well and the dash lights light up as well! If that makes any since... now to the things I have replaced! Turn signal switch in column, all new led lights in all spots except the headlights they are still one piece lights and I have also replaced the turn signal relay if anyone has ever ran into this or could lend any advice on what else I should check I would greatly appreciate it!!!!
Onto my problem..
