lostempire13
- Jul 4, 2017
- Age
- 39
Hi i need some help were stuck.
Replaced: Distributor cap
TFI
Spark plugs & wires
TPS sensor & connector
Fuel Injectors
Fuel pump
Fuel filter
Crankshaft hose and thing that goes in as well as breather
Battery
ICM
Map sensor and connector
FPR
O2 sensor
We have also changed oil done seafoam treatment in gas and oil as well as Lucas oil after the oil change, we've checked fuses wires etc and it still is hard idling, now under load, rpms fluctuate and there is a misfire. We checked the spark plugs again and the 6th had black ash so we got a new one and put a no foul stopper all the others are fine. PLEASE HELP!
Sent from my SM-G930T using Tapatalk
TFI
Spark plugs & wires
Fuel Injectors
Fuel pump
Fuel filter
Battery
ICM
FPR
O2 sensor
