colin-pm
Hello, I have an '86 B2 with the 2.9 and an A4LD. It is a 4x4 with a manual shift transfer case. Heres the problem:
When I'm in park, and shift to drive (overdrive) the truck wont move. It doesn't even idle down like its in gear. I rev it up a little, but it still doesn't go anywhere. At this point I would try reverse or drive and it still won't move(and that high idle). I have to shut off the truck, wait a minute, restart and than I'm able to shift into reverse or any of the other forward gears (except overdrive). It drives and shifts great if I put it into 3rd (not overdrive) and I can actually shift into O.D wile I'm driving(and the OD works), but if I let the truck slow down (to 30 mph) and I don't down shift into 3rd, the truck is once again unable to accelerate and I must come to a stop and repeat the first proceedure. I assume I have a converter lock up problem, or a 3-4 shift solenoid problem, but obviously that's just my best guess.
I bought the truck half a year ago, completely stock, and I have no idea how many times the odometer has gone around. I don't know any history on this thing, but the tranny and pan are awfully clean looking compared to the rest of the truck. It leaks fluid, but I keep checking and adding as needed. It will be a project truck, but I would would like to make use of the stock drivetrain while I search for a replacement. (D35, 8.8 rear, gears, 3.0 or 4.0 swap, would like to stick with an automatic.) Currently it has a 3" body lift, and about half way through a body job and some 33's waiting for the appropriate amount of suspension lift.
Thanks for listening, hope to hear some "easy to repair" news!
Colin
Colin
