86 2.9 intermittant crank no start (maybe no fuel injection)
valsound
York PA
Hi friends, first post.
Let me begin by saying that I've been through about half the 2.9 pages & am very impressed by the friendly tone & helpful nature of the forum.
I brought home my second "farm truck" 86 2.9 4x4 stick Ranger with 150,000 miles a few weeks ago. It's not roadable due to rust, but it's perfect for navigating between trees in the wood lot. Problem is when it quits in the wood lot & I have to walk back to the house & wait till it feels like running again.
When I bought it the seller revealed that it did have an intermittant problem, & he handed me a box of parts: Computer out of a 88 Bronco, a distributor, some relays, & a TFI Module.
When the truck runs, it starts & runs like new (so I know it can). Maybe 3 times now, I'll hit a bump & the truck shuts off. Then it cranks strong, & I have spark at the plugs. If I spray starting fluid into the throttle body, it runs a second then dies. So I'm pretty sure that fuel delivery is the issue.
The truck starts up like nothing is wrong sometimes a few minutes later, sometimes after a few days.
When it's not working, if I depress the schrader valve on the fuel rail, gas will spurt out under at least under some kind of pressure. Sometimes, I can turn the key to run, & I hear the fuel pump run & gas pressure builds back up in the rail. But sometimes (if I remember correctly) the pump didn't run & no gas would come out of the valve after it came out the first time.
So here's my first question:
I'm thinking it would be a good idea to buy a good fuel pressure gauge to check at several points: the schrader valve, & also tee into the line after the fuel pump & before the regulator.
Is there anything I should know to look for or stay away from when I buy the tool? What's the best source? Parts store, or Sears?
Thanks.
as with most things...economically purchased....tends to =cheap
check withe parts stores in your area some will offer tool rental...put down a deposit, use it, return when done ...get your funds back.....basically free tool use. just another option.
As for best /worst scenario, try to get something with a warranty of some kind and adaptability for different styles , makes and models....i went to sears
as far as your "new purchase" issue....it smacks of a bad TFI (aka ignition module) or fuel pump relay.....but your also correct in finding out the fuel pressure is .
the TFI can be tested at major parts stores...there is a test procedure in the Tech Library section here at TRS....look above for the tab
Thanks for the comeback. Tools, I like to collect them, so I'll probably buy the gauge. Although on things like spring compressors, I've done the "free rental"
In that box of parts I got was a fuel relay which I've swapped to no avail. (of course both could be bad I guess)
Since the TFI is so fun to get at, I haven't pulled it yet. (bright spot is another tool to buy).
A couple of questions as I try to trouble shoot when it acts up the next time.
Am I correct that this motor does not have a crank sensor & instead uses the pick up in the distributor to know when to fire the fuel injectors.
The fuel injector wires are hard to get to. I've tried to gently pull & wiggle one off to see how easy a noid light will install, but the connector wouldn't come off. (didn't want to break it) Is there a trick or clip to getting them off?
Fuel lines: Looks like there are 2. One goes into the bottom of the fuel rail & I see no disconect. The other goes into what I believe is the pressure regulator connected with a 3 inch rubber hose with clamps.
Would that be a good place to tee into to check fuel pump pressure?
What are those 1" round metal disc things in the fuel line? directional stop valves?
Thanks for the insight.
yes i believe that is correct that the pick coil/hall effect control spake /injector pluses
those if i understand correctly as to what you're referring to are disconnection places...you'll like this...requires a special tool to get at them.
more good info here http://www.fordfuelinjection.com/
that usually gets done on the shraider valve where you pressed to see if you had fuel
