daduke
- Sep 27, 2014
I recently bought an 86 ranger 2.9 manual not running off craigslist. i replaced the fuel pump in the tank and the fuel pump wiring connectors and now it runs. my current Problems are that if I sit and let it idle it will run for a little while and then just get slower and slower till it finally just dies . If I'm driving it, it will usually stall at stop lights until warm. and will periodically start to chug and try to stall but if I let off the gas and leave it in gear it will get over it or if I floor it it will sometimes fix itself too. ive ran computer diagnostics on the koeo test i get a code 18 for missing tach signal and a code for the egr which has been removed. koer test wouldn't complete but the scan tool i used is known for being flaky.
on a separate note I was going to check the base timing because I have a strong inkling someone has futzed with the distributor. ( the tfi plug cant be removed because its pointing into the valve cover) but I can't find the hold down bolt for the distributor and I don't want to check something I cant fix.
