Canndspam
So I just swapped a salvage a4ld that came off an '85 ranger into my '86 and everything hooked up fine and now shifts 1-4 all good and smooth but it wont shift into overdrive. One major difference between the 2 trannies that i noticed after the putting the new one in was the neutral start switch pigtail on my truck has five wires coming off of it plus a spring that came out of the center of the switch, the pigtail off the 85 (which the salvage yard included with the tranny) has 4 and no center spring. Don't know what this means exactly but if there was some minor wire splicing that I could do to make the OD work that would be great. Also the shifter linkage seems to be adjusted properly as all the other shift position do as they should, just the OD position does the same thing as D. But perhaps I should just count my blessings that the thing shifts 1-4 and leave it at that?
