Rangerfireman383
Ok guys, I've been lurking around here for quite a while, reading and looking at wiring diagrams, etc., but to no avail I cant get my truck fixed. The list of what has been done to it as far as checking wiring, diagnostics, etc could fill up a novel. When I originally started trying to fix it, it had a dead miss that was random and could not be forced to duplicate. After reading codes (koeo and koer), I came up with a PIP signal issue amongst other codes like ect, iat sensors out of test range. Pretty much every sensor on the engine has thrown a code and has been replaced, along with a rebuilt distributor, new coil, plugs, wires, IAC valve and solenoid and TFI module to name a few. Specifically after replacing the distributor, it started surging when it was started cold, sometimes cutting off, and will clear out after it warms up for a minute. It has progressively gotten worse, and electrical load will cause it to surge of cutoff even after it is warm. If the heat, or anything electrical is switched on suddenly, the engine will skip or even start surging and sometimes cut off. I am at wits end with it, and need some help. Ideas? Oh, forgot to mention that I took it to a well known mechanic that I have known for years who got it running better, but its still not right. Surely there is someone out there who has experienced this and has some ideas. Sorry for the long post, but wanted to be as thorough as possible.
