Bryce
OK, so I need to replace my 84 (build date 6/83) Bronco II front Brake Hoses. (frame to caliper part). I'm seeing 2 different models with 2 different time splits.
before/after 2/83 and before/after 8/83. It appears that calipers are the same, so I'm guessing it's a different bend to the hard line section or the frame side fitting is a different thread (can someone confirm?).
Nobody has these in stock, so I'll have to order them. I'm trying to make sure that I order the correct hoses (left and right side). I just have a 2inch lift (coils in front and add-a-leaf and larger block in the back) so stock length should be fine.
My question is, can anyone confirm what the correct date split is and, even better, someone tell me a brand and model number that they know would work on a 6/83 build date?
TIA, Bryce
TIA, Bryce
